5052ci with a Dp7100 doc feeder light copies
  • toddanderson
    • Dec 2005
    • 238
    5052ci with a Dp7100 doc feeder light copies.
    The copies are light when using the doc feeder. The copies are fine, good when using the
    Table glass. The light copies only shew when using the doc feeder.
    Replace the ccd, ran u411-u410 chart from the glass ok but when running the u411 chart through the
    Doc feeder it gives errors 20.
  • KYO_OEM
    • Aug 2011
    • 723
    Re: 5052ci with a Dp7100 doc feeder light copies
    Service manual say:
    Error 20/ Input gamma correction coefficient error
    Set the original correctly and execute again.
    Maybe U068 helpfull or check the scanner belt.
    Bulletin 2ND-163(K112)
