Kyocera additional memory
  • Leebs14
    • Feb 2014
    • 457
    [Misc] Kyocera additional memory
  • nikolai.aleksie
    • Feb 2016
    • 177
    Re: Kyocera additional memory
    Originally posted by Leebs14
    I have a number of the M5526 model out there and need to fit some additional memory to the machines as the customer is struggling to print or scan anything longer than 15 pages double sided, so I place an order with Kyocera for 2 x 870LM00101 - 1GB memory stick, only to be told that they no longer stock this item and it’s been discontinued. Anyone know where I can buy this memory? Is it standard laptop memory or not?
    870LM00101 looks like standard laptop DDR3 SDRAM - 144-pin - SODIMM 1333MHz. You can try. I have TaskAlfa 3500i and Xerox Phaser 7400 upgraded with standard laptop memory.
    • Luther
      • May 2006
      • 682
      SD-1GB 855D200754 1GB DDR3 Memory DIMM,SD-512MB 855D200753 512MB DDR3 Memory DIMM, these are the memory options for the M5526
      • copier tech
        • 8196
        • nikolai.aleksie
          • Feb 2016
          • 177
          HDD and ECOSYS M5526 ?! There is no HDD...
          • copier tech
            • 8196
            That will teach me to check the model first before replying.
