3551ci, color difference
    • 16374
    I have 2 3551ci's in the shop. Both using OEM toner. One has 100k on it. The other has 50k. When I print out the test charts there's a difference in color. See test charts below. Notice the difference in the last row of color. One is magenta and the other looks purple. There's also a more slight difference in the blue.
    Maybe someone with more experience than me can give me a clue. Thanks. See below:
    colors off.pdf
  • Mikeber12
    • Feb 2021
    • 2
    Re: 3551ci, color difference
    [ATTACH]48308[/ATTACH]
    Run toner curve or it maybe called auto gradation...that should fix it
    • Mikeber12
      • Feb 2021
      • 2
      Run toner curve... hope that helps
        • 16374
        I've done all of that. Ran multiple calibrations. Nothing changes.
        I'm thinking the problem lies in the cyan DV unit. Blue + red = purple and the blue looks off to me.
        • tsbservice
          Field tech
          • 8007
          More likely it is drum than developer unit. It's easier if you print full bleed solid patterns CMYK at 100% and at 50% density. Also one good thing I learned from Kyocera they use green pattern to actually determine Yellow color conditions(too weak itself).
            • 16374
            More likely it is drum than developer unit. It's easier if you print full blead solid patterns CMYK at 100% and at 50% density. Also one good thing I learned from Kyocera they use green pattern to actually determine Yellow color conditions(too weak itself).
            That's interesting. This should be a good learning experience for me as I have never encountered this problem before. I wanted to get some advice before I started swapping parts/supplies. I don't think I have any 100% solid test patterns. I have all the other ones.
              • 16374
              Here's the internal test charts, for what it's worth....
              doc20210216123422.pdf
              doc20210216123413.pdf
              • copier tech
                • 8142
                Well you have 2 machines next to each other start swapping parts to narrow it down.
                For example first swap all drums & go from there.
                Are they both on the same firmware version?
                  • 16374
                  Both have latest firmware and it's the best firmware in the world....I got it from you.
                  On a serious note, I'll try swapping the drums first and see what happens.
                  • tsbservice
                    Field tech
                    • 8007
                    Good place to start with just mark all of them BEFORE start swapping or you can be a bit confused at the end. I would start first with K and C drums. Also in the future please try to give us not machine total counter especially they're color models so counter 100k may well be something like 95k black + 5k color as well as 40k black + 60k color(big difference in parts life counters = wear).
                    • kyotechnz
                      • Mar 2019
                      • 144
                      Try cleaning the scanner and running U410. If the mirrors in the scanner are not clean the machine may not recalibrate properly.
                      If you have the right chart, recalibrate the scanner. It may need resetting up. U425 and U411
                      Also clean the sensors that read the patches on the Transfer Belt as well. If it is not reading the patches correctly the colours may not come out right.
                      Running U412 may help as well.
                      • mga
                        Copier Technician
                        • Dec 2010
                        • 1393
                        Did you clean optics and laser before calibration
                        Regards Mark
                        • copier tech
                          • 8142
                          Thank you for your support.
                          Are both machines in the same room? Temperature can make a difference.
                            • 16374
                            Yes, cleaned laser before running calibration. Also cleaned ID sensors.
                              • 16374
                              Both machines are in same room sitting side by side.
