kyocera 5053ci
  • tee
    • Aug 2014
    • 79
    kyocera 5053ci
    I replaced the magenta dv unit and recalibrated.
    prints and copies both have magenta distortions.
    I am trying a primary belt next, anybody have a
    Taskalfa 5053ci with images like these samples?
    • 16416
    Re: kyocera 5053ci
    What's the page count on the DV's and DR's?
    If I had to guess from the examples that you posted, I'd say it's a magenta drum cleaning problem.
    Also, you need to run some solid test patterns. See below:
    11% ANSI A Color 8.5 x 11.pdf
    • tee
      • Aug 2014
      • 79
      Re: kyocera 5053ci
      70k
      drums swapping changed nothing
        • 16416
        Re: kyocera 5053ci
        If it were the transfer belit, I'd expect to see more than one color affected.
        • tsbservice
          Field tech
          • 8021
          Re: kyocera 5053ci
          Look like something badly with magenta developer unit - magenta drum unit combo. Why you changed M developer unit, what was your initial problem?
            • 23009
            Re: kyocera 5053ci
            It sure looks like bad developer spacers to me.
            Was it a new unused developing unit? Or a unit of unknown provenance? It sure does not look like a new magenta developing unit to me. =^..^=
              • 16416
              Re: kyocera 5053ci
              I believe you but how did you determine this? It looks different than the bad spacers on my example that you pointed out. Thanks.
                • 23009
                Re: kyocera 5053ci
                The way I understand it, when the spacers wear, the distance between the developing roller and the drum diminishes, and starts arcing. =^..^=
                • tee
                  • Aug 2014
                  • 79
                  Re: kyocera 5053ci
                  I fixed it by reconnecting and cleaning all high voltage connections.
                    • 23009
                    Re: kyocera 5053ci
                    Thanks to the followup, tee. =^..^=
