Kyocera M3040idn printing problem
  • zalazXT
    • Mar 2021
    • 11
    [Misc] Kyocera M3040idn printing problem
    Hello, i have a problem with my printer, tried everything i could, not sure what to do.
    The problem is half of page is grey lines this happens even printing a blank page, if density is increased it gets much darker, and even makes whole paper background grey, left side gets very dark.
    Any suggestions?
  • patrickjlc
    • Feb 2015
    • 225
    Re: Kyocera M3040idn printing problem
    Could be a bad developer or charge roller. Cleaned the glass?
    Can you upload a picture, and how many prints the machina has
    Sent from my motorola one 5G UW using Tapatalk
    • zalazXT
      • Mar 2021
      • 11
      photos IMG_5071.JPG - Google Drive, IMG_5069.JPG - Google Drive
      • zalazXT
        • Mar 2021
        • 11
        Glass is cleaned, but this happens even with blankn page printed from computer
        • zalazXT
          • Mar 2021
          • 11
          Pictures IMG_5071.JPG - Google Drive
          Machine has 89K printed.
          • copier tech
            • 8153
            Originally posted by zalazXT
            I guess you are not a tech? This is a basic issue.
            You simply need to replace the drum.
            • patrickjlc
              • Feb 2015
              • 225
              That looks like a bad charge roller, the grey thing on top of the drum. Remove it, and see it had the same marks. Could try cleaning it with a cloth and some cleaning solution untill you get a replacement.
              • zalazXT
                • Mar 2021
                • 11
                I dont have much experience i know, thats why im asking for help
                • zalazXT
                  • Mar 2021
                  • 11
                  Not sure if its that bad
                  • copier tech
                    • 8153
                    The Kyocera M3040idn does not have this type of charge roller.
                    • patrickjlc
                      • Feb 2015
                      • 225
                      Yes sorry, got confused with the 3550 and 3540 idn.
                      • zalazXT
                        • Mar 2021
                        • 11
                        It has this roller
                        • ntbann
                          • Jan 2012
                          • 628
                          I wouldn't use cleaner on charge rollers. It can dissolve the outer coating making tor roller junk. Strait water works the best.
