ecosys p 5021
  • Gab
    • Aug 2015
    • 671
    ecosys p 5021
    After power failure printer doesn't print. I printed from printers menu report with no problem but when i try to print from computer screen changes and message that will reset and restart appears . \Also message "interupt code , APC index mismatch" appears and computer restarts. This happens every time i try to print. I can print with no problem from computer to copier taskalfa 5501i that client has at the network too.
    I installed again drivers with no result. Computer is connected to network by wi fi. Internet works fine.
    Any idea?
  • copier tech
    • 8153
    Re: ecosys p 5021
    Any idea?
    Sounds like the recent issue with a MS update.
    Update the machine firmware & check this link.
    Windows 10 KB5000802 (March 2021 update) has been going seriously wrong for some PC owners in the last twelve hours, with several users reporting that the botched update is causing Blue Screen of Death errors when they use printers. To make matters worse, KB5000802 is an automatic security update, which means it has been downloaded […]
