Taskalfa 520i blur trail edge
  • beaker020
    • Mar 2006
    • 63
    I have a customer with a TA 520i with half a million copies. When using 30# paper and delivering to the finisher there is a blur 25-30 mm from the trail edge. Fuser has been replaced, Firmware is up to date. No blur if delivered to the internal tray and no blur on 20# paper.
    any ideas?
    Lance
  • darry1322
    • Oct 2010
    • 817
    Re: Taskalfa 520i blur trail edge
    any ideas?
    Lance
    Broken and missing spring from the end of the transfer roller. Usually the drive end.
    • patrickjlc
      • Feb 2015
      • 225
      Also check where the transfer roller goes, the plastic film on the door. For rips or lifting edges. It has to be smooth to the touch.
      Sent from my motorola one 5G UW using Tapatalk
        • 23010
        30# bond or cover or index or points or book?
        GSM is what I look at, to get around all that obscurity. =^..^=
        • JR2ALTA
          • Feb 2010
          • 2033
          We're assuming you've tried different paper settings? Looks like it's buckling at the fuser. Fuser speed changes when paper type changes.
          • kleankopy
            • Feb 2016
            • 115
            Transfer Roller Assy.
            • kjg
              • Mar 2009
              • 112
              try replacing the drum entry guide. its the metal one that comes in the PM kit. I have had several do just that but it shows on 20 pound paper too.
