Jam on my Kyocera FS-1300D
  • richard5020
    • Mar 2021
    • 12
    [Jamming] Jam on my Kyocera FS-1300D
    I'm looking to fix the jam on my FS-1300D and will make a contribution if I can get the fix via this website. Was printing A4 size paper OK. I did a print job for A5 and that printed OK. I've now gone back to printing A4 size but now get a jam. I have got the printer to print out, but it's hit and miss, and currenly paper is always jamming. I've cleaned all the rollers I can get to. The paper gets picked up fed into the machine, and just as the sheet is about to come out at the back, the printing stops and a jam is indicated. There is only one sheet inside the printer mechanism. Set to duplex. I've tried to get an event log, but not sure if I'm doing things correctly. I chose the share and gave a name (FS-1300D). Here is a copy of my DOS screen:
    Microsoft Windows [Version 10.0.19041.867]
    (c) 2020 Microsoft Corporation. All rights reserved.
    C:\Users\dell>net use
    New connections will be remembered.
    There are no entries in the list.
    C:\Users\dell>net use ltp3 \\ 127.0.0.1\FS-1300D
    The syntax of this command is:
    NET USE
    [devicename | *] [\\computername\sharename[\volume] [password | *]]
    [/USER:[domainname\]username]
    [/USER:[dotted domain name\]username]
    [/USER:[username@dotted domain name]
    [/SMARTCARD]
    [/SAVECRED]
    [/REQUIREINTEGRITY]
    [/REQUIREPRIVACY]
    [/WRITETHROUGH]
    [[/DELETE] | [/PERSISTENT:{YES | NO}]]
    NET USE {devicename | *} [password | *] /HOME
    NET USE [/PERSISTENT:{YES | NO}]
    C:\Users\dell>net user
    User accounts for \\DESKTOP-9XHF3VT
    Administrator DefaultAccount dell
    Guest WDAGUtilityAccount
    The command completed successfully.
    C:\Users\dell>ECHO !R! ELOG; EXIT;>lpt3
    The system cannot find the file specified.
    • 23010
    Re: Jam on my Kyocera FS-1300D
    What paper size is designated for the paper tray? Paper jam timing is based on paper size. =^..^=
    • richard5020
      • Mar 2021
      • 12
      Hi I think I've fixed the problem by selecting the tray as source, where the printing was OK, and then selecting cassette 1. Maybe there was a software glitch. But, I've now got a new problem and I must fix that before I 100% know if there is no more "paper jam". EDIT: OKwhat I had to do is get into Status Monitor and change Cassette 1 from A5 to A4. That fixed the "jam".
