Kyocera - Number of possible adress book entries and LDAP function
  • i-have-no-clue
    • Feb 2014
    • 14
    A customer has a 3645dn black & white Kyocera A4 MFP because of prescribe printing issues from some software. Ok.
    But he wants to store over 700 Email adresses in the MFP. But all A4 Kyo MFP have only 200 or 250 adress book entry possiblities, what I have seen.
    Is this correct? He would need a A3 machine with 2000 ones, right?.
    The next thing is, the IT admin has to implement the email adresse in the active directory, so we could use the ldap funtion of the machine.
    What are experiences here regarding the speed for the ldap search. The 3645 dn has no touch panel. I fear the handling will be to complicated to search for the email via ldap. And for what I've seen at other customers I'm not sure that ldap will work at all.
    What do you think?
    • 23010
    Re: Kyocera - Number of possible adress book entries and LDAP function
    To me, this sounds like ridiculously poor mismatch of customer needs to machine capabilities.
    Yes you can have up to 200 individual addresses stored, and up to 50 groups.
    Yes LDAP can give you access to more addresses. With a pool of 700 total addresses, if you arbitrarily selected "A" you would have to browse through 20 line entries to find your destination starting with an "A", and depending on the network speed you'd wait 30 to 60 seconds to see the results of your search. Sounds quick, yes? ... until it's you doing it.
    I had a Kyocera customer with 2010 job account ID's they wanted available. The technology at the time allowed 2000 entries, but in actual practice the machine bogged down to a crawl beyond 1990 entries, and would not accept another after 1996 entries. After spending several days on this, we loaded it to a machine in the controllers office. The ladies struggled with it with surprisingly few complaints, but when the controller had to go through the same steps, and wait and wait and wait ... the whole idea was scrapped. It's too bad they couldn't have scrapped the idea a little sooner, before I put in so much time on it.
      • 23010
      Just as a side note, I spend three days entering address book entries from a customers prepared LDAP list of 500 entries. Note that this list included every address ever emailed to, and included all the misspellings as separate lines and every inactive email destination. A popular individual with a difficult to spell email address might have 6 or 7 lines of which only one was correct. I went through a sorting process starting with the "A's" ... but it didn't make the process any quicker, and it wasn't necessarily obvious which one was the correct entry. I would suggest that you not follow my example on this. =^..^=
        • 30554
        Not sure if Kyoceras can do this anymore but we had a customer use a csv file that machine looked at for addresses.
          • 16524
          That sounds like a f'n nightmare.
            • 23010
            It was the bosses friend, so we spent way too much time on this install. 40+ PC's, and the addressbook debacle (at no extra charge). =^..^=
              • 30554
              Quite common for enterprise size companies to use LDAP
              • tsbservice
                Field tech
                • 8064
                Good learning experience for both - you and your boss. Otherwise you can't describe them how it can take so many hours for so "easy" job.
                I learned to get most from those rare situations, standard is - you did this for a minimal time before how it comes it took 3 hours to install and configure MFP scan and print to 10 separate PCs
                • i-have-fax-problems
                  • Mar 2020
                  • 108
                  You mean, you put a csv file of a certain format in a shared network folder and the kyocera searches the csv file then.
                  How this should work?
                    • 30554
                    Only saw it once you would have to call Kyocera to see if its still possible. External address book
                    LDAP would most likely be the way
                      • Mar 2020
                      • 108
                      I'm not sure about the LDAP function. IT Admins told me that you can only use internal email adresses from your Acitve Directoriy but not external ones from your customers. The customer in this case wants to
                      send invoices to his cumstomers. But this are external mail adresses.
