TA 4012i jam 4901
  • Step
    Senior Technician
    • Sep 2015
    • 42
    [Jamming] TA 4012i jam 4901
    Hi All
    Have this machine giving me issues on jam 4901. The exit unit is the only unit already replaced but made no difference at all. The only other parts replacement was feed rollers on Cass 1 and 2 just for FYI.
    I do not find any service bulletin on this.
    Any suggestions please.
    My thoughts on this is to try and replace the fuser next and see if it helps.
    Thank you all
  • KYO_OEM
    • Aug 2011
    • 715
    Re: TA 4012i jam 4901
    On several systems we removed item #11 + #12 from exit unit and it works well.
    Mostly if bad kind of paper would used, we got this jam code.
    partslist, fig. 26, exit section:
    • Step
      Senior Technician
      • Sep 2015
      • 42
      [ATTACH=CONFIG]48685[/ATTACH]
      Thank you for your reply. I will remove these items from the exit unit and test on my next visit.
