Kyocera Job Accounting - Import / Export
  • kuby
    • Oct 2007
    • 1410
    Question? Can you import a Job Accounting list from one Kyocera machine to another? Never did this and do not see a Import/Export button.
  • progoffice
    • Nov 2008
    • 337
    Re: Kyocera Job Accounting - Import / Export
    This can be done via Net Viewer and also via U917 using the Setup Tool.
    • kuby
      • Oct 2007
      • 1410
      Thanks, Will try that.
      • kuby
        • Oct 2007
        • 1410
          • 30430
          You have to add the accounting module to KM Netviewer on install as an option
          • kuby
            • Oct 2007
            • 1410
            Should have added, trying to do it by Remote as the machine is 50 miles away.
            Used to work on Canon's and they have a import/export feature for the address book. Just did not know if that could be done by remote for the Job Accounting on the Kyocera.
            • ntbann
              • Jan 2012
              • 631
              You can pull a 917 through KFS. Just have to get the customer to hit yes on copier.
              • dickierock
                • 252
                Hiya, how do you add the accounting module?
                Thanks.
                • PrintWhisperer
                  • Feb 2018
                  • 473
                  Thanks.
                  Run the KNV installer and there will be an option to add it.
                  MM917 will not exchange files between different models (diff series or CvsBW). The files can be converted using the SetupTool.
                  Netviewer requires you to be on-premise or VPN.
                  Kyocera Device Manager will be replacing KM-Net Viewer but at last check does not have Multi-Set for Accounting yet.
                  "Being ignorant is not so much a shame, as being unwilling to learn" - Benjamin Franklin
                  • JR2ALTA
                    • Feb 2010
                    • 2033
                    Yea 917 is worthless for this. I couldn't even transfer addressbook from from a 306ci to a 308ci. It's basically just to back up that machine in case you need to reload info.
                    • sparkycivic
                      • Apr 2017
                      • 348
                      The Setup Tool(from downloads section of portal) converts the user info, job accounting, and full address book between device models for exactly this purpose. It can also edit address books directly. Use the "convert" menu option, point to a source folder containing u917 data, pick a destination model, then pick a destination folder for output. Place output files in root of a stick, u917 on destination machine, choose first four buttons: address bk, job acct, one touch, user. boom, done!
                      • JR2ALTA
                        • Feb 2010
                        • 2033
                        Excellente!
                        • yakyitz
                          • 245
