trouble code
  • antone
    • Oct 2014
    • 344
    trouble code
    New to this M8124...trouble code F244...help
    Sent from my SM-N981U using Tapatalk
  • avio2
    • Jul 2010
    • 150
    Re: trouble code
    more error F24X related to print PDF file , try update firmware and "set print as image "
    • copier tech
      • 8149
      Re: trouble code
      As the previous post said, either a corrupt print job or firmware needs updating.
      • Code: F24X
      • Description:Abnormality detecting in the system Management Department
      • Causes:F248 is the abnormalities of a printer process. In recurring by specific printer data, please give me cooperation at acquisition of capture data and USBLOG.
      • Remedy:(1) Check contact of a DDR memory and perform an operation check. (2) Initialize SSD and perform an operation check. * (3) Carry out U021 Main backup initialization and perform an operation check. (4) Exchange a Main board and perform an operation check. (5) Exchange SSD and perform an operation check.* (6) Get USBLOG and contact service headquarters. * Only SSD standard model. (7) Update the main firmware.
      • Scott
        • 196
        Re: trouble code
        I have found that most of the F*** codes are corrupt files mostly from printing from internet
        • copier tech
          • 8149
          Re: trouble code
          This is correct. Updating the firmware resolves these issues.
