4501i Perfect copies, light prints and reports
  • bcopier2815
    • Oct 2015
    • 42
    We have a 4501i that makes perfect copies. Prints and status pages are very light and washed out. Eco mode actually improves the prints. Any Ideas?
    • 900
    Re: 4501i Perfect copies, light prints and reports
    Are you sure your turning off eco mode in the printer settings in system menu.
    • bcopier2815
      • Oct 2015
      • 42
      Yes
      • tsbservice
        Field tech
        • 8020
        This sounds like a perfect crime...impossible!
        Can you post samples?
        • Ropariva
          • 678
          Yep. Guarantee it is in eco print mode. Post up a pic of the status page.
          • JR2ALTA
            • Feb 2010
            • 2033
            What the guys are getting at is there's TWO eco modes. One for copy, another for print.
            • tonerleak
              • Mar 2012
              • 67
              Yes in Function defaults in the common settings menu and in the Printer settings in the system menu.
              • bcopier2815
                • Oct 2015
                • 42
                IMG_0460.jpgimg maint.pdfimg maint.pdf
                Replaced ID sensor, HV PCB, Drum unit, dev unit
                • bcopier2815
                  • Oct 2015
                  • 42
                  IMG_3639.jpgThis is what prints in reports. If I do turn on eco mode, the prints IMPROVE!
                  • masterchill
                    • Jul 2005
                    • 100
                    I would try a full machine reset. Something is not adding up.
                    • bcopier2815
                      • Oct 2015
                      • 42
                      already tried sim 2 , 21 , 24 still the same
                      • tsbservice
                        Field tech
                        • 8020
                        This is something wrong with how machine processes images/data. If copies are good you can elimanate 99.99% all hardware parts like high voltage, drum, dev, transfer, even laser. It has to be board, memory or something in that venue.
                        • progoffice
                          • Nov 2008
                          • 336
                          Have you tried printing out any of the Sim 089 samples? I agree that this appears to be a board issue. It looks like your firmware is pretty current too. The Main PWB controls the print data processing, so you might give that a try.
                          • Ropariva
                            • 678
