Reset
  • SL65
    • May 2021
    • 5
    Reset
    Hello,
    I have purchased a Kyocera M6535cidn from a liquidated company and when i start it up it is trying to connect to a server and i cannot access the admin login as i dont have the username and password supplied with it.
    Is there anyway i can sort this issue out? May be i can hard reset the machine?
    TIA
  • GIUBOSS
    • 1433
    Re: Reset
    you have already tried with the default: Admin, pw. : Admin?
    • SL65
      • May 2021
      • 5
      Re: Reset
      Yes I tried no luck
      • GIUBOSS
        • 1433
        Re: Reset
        if your machine has a lock with an access code, you need to log in to administrator mode. As a last resort, restore in service mode
        • spw
          • Mar 2015
          • 62
          Re: Reset
          Might try the numerical value of the model number.
          for example on Kyocera 420 you can put in 4200 for the pass and its the same.
          i dont know what it is for a 6535 but you could try 3500 or something along those lines. But ya Giuboss is right its default is Admin Admin.
          • ntbann
            • Jan 2012
            • 628
            Re: Reset
            3500 3500 is correct for a 6535
            • progoffice
              • Nov 2008
              • 334
              Re: Reset
              Have you tried running maintenance mode 21? This should initialize the machine back to out of the box status.
