406ci not printing Yellow
  • kuby
    • Oct 2007
    • 1409
    Have a 406ci that is not printing the yellow. Have put a developing unit it and a drum unit from a good machine and still nothing. And the ones from this machine work in the other machine?
    Glass under the dev/unit unit is clean.
    • 16416
    Re: 406ci not printing Yellow
    Is the DV unit turning? Sounds like you lost drive to the DV unit.
    • kuby
      • Oct 2007
      • 1409
      Found the problem. The yellow developing unit did not latch properly on this one. Fixed and making yellow now.
      • FriendlyTech
        • Jan 2018
        • 30
        That little gray button on the developer will get you every once in a while.
        • copiertec
          • Jan 2016
          • 2211
          I ran into the same issue when on a 5002i, on a new client. Had me going for a few, retraced my steps and it turned out to be that grey lock on the developing unit.
          • KYO_OEM
            • Aug 2011
            • 721
            If i get "white eagle on white paper", i remove the MC at first to see if i get solid color on DK unit without MC.
            (On systems with aSi DKs you has to set U100/ AC "auto adjust" to "OFF" before, to prevent C510x/ OPC not needed)
            Still blank--> HVT DV, no contact between DV<-->DK (grey hook), DV don`t turn...
