kyocera 7551ci ocr error after hdd replacement
  • Choclit007
    • Oct 2010
    • 58
    [Error Code] kyocera 7551ci ocr error after hdd replacement
    Recently I replaced the hdd after it failed & coded. Reloaded latest firmware. ok. I thought.
    OCR error came up today.
    Now I read in the SM that the OCR data dictionary needs to be replaced after hdd replacement.
    Where do I get it?
    I do not see it on the firmware download page.
  • tmaged
    Owner/Service Manager
    • Oct 2008
    • 1890
    Re: kyocera 7551ci ocr error after hdd replacement
    It should be in the normal firmware since the OCR is included on those models. I'd make sure to do full firmware, not the turbo.
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
    • Choclit007
      • Oct 2010
      • 58
      BINGO!
      Thanks so much
      All good after full fw update to latest
