kyocera p3150 image quality
  • tmw
    • Dec 2013
    • 259
    The attachments will show blooms of toner marks under vertical lines and text randomly down the page. This was put in new at the beginning of Jan. and has just over 80,000 pages. I cleaned dust from the whole paper path, took out &amp; cleaned transfer roller and static teeth. Cleaned excess dust from around drum blade. Cleaned charge roller &amp; all contacts. Tried different settings up and down for mc roller, transfer roller, and density. I can't tell if the image diagrams in the book address this specifically, I followed the suggestions of the ones that might be related.&nbsp;<br>I don't know if this is connected to the fuser problem it had in the beginning. They had it a couple weeks and the pressure roller got coated in toner build up. Clean it off and it would come back in a week &amp; 1/2. Replaced it under warrantee and it doesn't seem to build up like before. There were only a couple specks on it this time but I should have expected none.<br>I will end up calling kyocera too, but collective knowledge is nice as well.<br>Thank you<br>OK, my images refuse to upload. You can read this &amp; my colleague will try to put them up.
    • 23008
    Re: kyocera p3150 image quality
    Maybe knock-off toner? =^..^=
    • tmw
      • Dec 2013
      • 259
      It is oem toner. We won't use anything else for these.
        • 23008
        I've seen this before, but don't remember what I did. =^..^=
        • spw
          • Mar 2015
          • 62
          Couldn't see any of the attachments?
          I see you had a similar if not the same problem a while back. Here> ecosys p3150 pressure roller build up
          Did any of this work for you with the settings?
          we tried this and it worked for us.
          Hope it helps!
