KYOCERA TASKALFA 8002i
  • Jahead
    • Apr 2021
    • 5
    [Error Code] KYOCERA TASKALFA 8002i
    C7101 on Kyocera Taka Alfa 8002i. The MFP developer unit is spilling any solution to this problem will be highly appreciated. I have tried serving the dev unit several times without success.
    Re: KYOCERA TASKALFA 8002i
    Originally posted by Jahead
    C7101 on Kyocera Taka Alfa 8002i. The MFP developer unit is spilling and reason and solution to this problem will be highly appreciated.
    how many pages on the service parts?
    how many pages total?
    are the filters clean?
    have you changed the dev units?
    what have you done?
      • 23008
      Can you get the error to clear temporarily? If yes, enter service mode > U030 and run the developer motor. If it does not run, you might have a bad developing motor. Very similar motors are used in the KM-6550ci, KM-7550ci, KM-6551ci, KM-7551ci, KM-8002i, KM-8003i. I suspect that 302K994890 through 302K994894 are all updates in the same motor. If you manually rotate the motor you might hear loud clicking. This one was in a KM-6551ci:
      • Jahead
        • Apr 2021
        • 5
        700k but the MK had been changed at 500k
