customer has 2 of these one had gray back round and streaks i believe the developer unit so i swaped dv units and the streaks and gray went away so i confirmed the dv unit needed replaced
I installed a new dv unit went to sys maint chose new developer and followed the prompt to reboot the machine it started running and said adding toner no problem right except its just running and running saying adding toner this is a brand new oem dv unit and toner I read the book which doesnt say much about replacing the dv unit then I came across a toner add option it says sys maint choose developer hit start then hit yes (left arrow) and toner will rapidly add i havent gone back yet to do the toner add do you guys think that will work ordi i do something wrong this should have been an easy install but nooo i need your input
thanks to all that help
bruce
bruce
