taskalfa 5501
  • Gab
    • Aug 2015
    • 671
    taskalfa 5501
    Can anybody tell me if Taskalfa 4500i has the same paper feeder with Taskalafa 3501i?
    Also if TA 5500i uses the same fusing unit as 4500i?
    • 23009
    Re: taskalfa 5501
    Originally posted by Gab
    Can anybody tell me if Taskalfa 4500i has the same paper feeder with Taskalafa 3501i? ...
    Document processor? DP770B/DP772 Yes
    Paper feed pedestal? PF730B/PF740B/PF770 Yes
    ... Also if TA 5500i uses the same fusing unit as 4500i?
    FK-6306? Yes
    • nikolai.aleksie
      • Feb 2016
      • 177
      Re: taskalfa 5501
      document processor? Dp770b/dp772 yes
      paper feed pedestal? Pf730b/pf740b/pf770 yes
      fk-6306? Yes
      fk-6306 110-120v
      fk-6305 220-240v
      fk-6307 220-240v
      • eddie110171
        • May 2012
        • 133
        Re: taskalfa 5501
        The paper feeds are interchangeable but keep in mind the paper feed for the 01s will have the rollers that you can service from the front and the 00 paper feed you have to take apart the side and remove the paper feed in order to replace the paper feed rollers. FWIW
        Also if you use the FK-6306B for the 120v it fits both 01s and 00s. It is backwards compatible from the 01 to 00
