KYOCERA Task Alfa MZ3200i. need to enter in maintenance mode but NO ID Account
  • Bob-Sponge
    • May 2024
    • 14
    We have on the field an MZ3200i that has "frozen", juste by doing un print of .doc file. message is "fatal error no printing no scan no fax available"
    We would like to enter into the maintenance mode with the appropriate code, 10871087, but it is impossible as machine is requesting an ID an account ID (numerical only). We do not have this ID, normaly it is supposed to be 3200, but it is not recognized. As the machine seems to be locked, we are unable to do anything else. Does anybody can help us? Regards estimate colleagues
    This gallery has 5 photos.
  • yakyitz
    • 245
    Press, the job status/cancel button which should be accessible even without an account ID number, then bring up the numeric keypad and enter maintenance mode as usual
    • Bob-Sponge
      • May 2024
      • 14
      Hello, thank you for your answer, but when i push on the status/cancel, automatically, it asks me Account ID.
      • KYO_OEM
        • Aug 2011
        • 725
        create c-call C7901 by disassembling drum to get entrance to 10871087. Run U906 for reset partial operation function
        • Kyodogs
          • Apr 2024
          • 12
          Power down the machine, open right side door, power up and you can get into maint mode. (shut door if you have to execute)
          • Bob-Sponge
            • May 2024
            • 14
            By disassembling, do you mean remove the drum??
            • Bob-Sponge
              • May 2024
              • 14
              Any way to get Service Manual?
              Regards.
              • KYO_OEM
                • Aug 2011
                • 725
                yes, remove dk unit, manual not needed for this. You also can remove FK unit....no screwdriver or else needed.
                • KYO_OEM
                  • Aug 2011
                  • 725
                  by the way, do not use security level 3 if you want to use full functionallty. enclosed how to remove the drum. close all covers without mounted drum and start up again. Do not forget to remove power plug from wall outlet before! drum disassembling.pdf
                  • nathicana
                    • Aug 2008
                    • 335
                    If all you want to do is run u906 press the three dots in the upper right of the control panel then bring up the numeric keypad. You should be able to get into maintenance mode from there.
                    • Bob-Sponge
                      • May 2024
                      • 14
                      Excellent Thnak you.
