secret code kyocera
  • microzelig
    • Jul 2021
    • 7
    #16
    Re: secret code kyocera
    Originally posted by kuby
    And another thing...Kyocera has a warranty policy that you can show them when your purchased the machine and how many copies were made before a part failed. If you turned back the counter then tried to get warranty for part failure then that would be FRAUD....plain and simple. Another reason you can not roll back the counter.
    Add that to make a another reason, and the answer is still NO.
    then, (let's make a bit of controversy) I see that you don't know how it works, at least for kyocera Europe.
    The warranty is 14 months from the dealer's purchase date (not when you sell it to the end customer, then there are kyolife formulas if the customer registers and pays for the extension) regardless of the copies made. The warranty within 14 months with copies is valid only for MKs which on average last 4 / 500,000 copies, I challenge anyone to make 500,000 copies in 1 year
    so the purpose cannot be what you think, you think it because you would and the mind thinks that because it is distorted.
    mine was a naive request to do what I explained yesterday, without any thought to deceive anyone, we don't need to believe me.
    • microzelig
      • Jul 2021
      • 7
      #17
      Originally posted by terramobil
      It's easy: Turn the machine upside down while printing and the counters will run backwards.
      Be careful to say certain things, that some smart and intelligent technician could take advantage of your advice and implement it
      ha ha ha with all these professors around ... you never know
      • KYO_OEM
        • Aug 2011
        • 727
        #18
        I think we can close this case because it is not possible to enter hidden Service Mode by normal technician!
        To get entrance you need KDC headquarter secret code + special USB key, provided by KDC.
        Serialnumber from this special KDC-USB key will be stored in each FW to prevent copy and paste to other USB key.
        There is no other way possible anymore!
        By the way: you can't reset all counters by the secret code together with usb key.
        Life count will still remain.
        • Scottb
          • Apr 2013
          • 308
          #19
          not to get in the middle of reset or not...
          Just log in to the Command Center change the Host name and it will show up on kfs so you can tell who is who and new from old
