Kyocera ecosys m3645 jam9120
  • Casian55
    • Jul 2019
    • 18
    [Error Code] Kyocera ecosys m3645 jam9120
    Hi everyone, I'm facing a strange error code on a Kyocera ECOSYS M3645. I suddenly get error code JAM9120 as soon as I try to copy or scan from ADF unit.
    I've found this on a manual: "initial jam of DP timing sensor When DP reading is begun in the state where the manuscript remains in the conveyance way"
    As i press the copy/scan i get the JAM error almost instantly, nothing starts moving, either gears.
    I have also noticed that there's something wrong with the paper sensor: when I insert some paper in the feeding section, the paper is being detected, BUT when I remove the paper sheet the sensor doesn't come back to it's original position.
    Any suggestion? I've seen there's very little info online about this model, maybe because it's a recent model.
  • avio2
    • Jul 2010
    • 150
    Re: Kyocera ecosys m3645 jam9120
    [QUOTE=Casian55;1850973][/CITAZIONE]
    controlla che si agganci bene lo sportello e non abbia gioco la leva del sensore portebbe toccare contro la plastica che protegge il sensore stesso(quello verso sx aprendo lo sportello) quello che tocchi tu ritengo sia quello di presenza documento non quello di registrazione)
    controlla nche che non si siano allentate le viti che fissano la cerniera sx o che non sia crepato
    perdonate l'italiano ma raramente ne trovo qualcuno qui
      • 23007
      I know of another tech with a similar issue on a Polaris2 that ended up replacing the DF assembly for this issue. Swapping DF's moved the issue to another machine in the office. =^..^=
        • 30200
        If it's a switch check the mounted ie snapped in or see if the actuator and spring is seated correctly.
        • Casian55
          • Jul 2019
          • 18
          tbh I already did that xD now I'm trying to solve the problem because I have this DF mounted on a brand new MFP.
          • Casian55
            • Jul 2019
            • 18
            can you be more specific? what do you mean with "ie"? I've already dismounted the whole DF unit and everything looks at its place.
            • avio2
              • Jul 2010
              • 150
              • Casian55
                • Jul 2019
                • 18
                I already tryed to manually activate sensors and they're working fine. the 2 problems are: paper sensor (N#5 in the manual) is not returning to it's original position and the paper pickup roller doesn't go down to pickup the sheet.
                • avio2
                  • Jul 2010
                  • 150
                  the pickup roller don't pickup a sheet because the registration sensor or lever is faulty
                  i have simulated your error in one mfc similar ,look were i put folder sheet
                  look a pics
                    • 23007
                    Originally posted by avio2
                    ... "manually implements the sensors in correspondence of the levers, as I wrote in the 1st post those you see on the top if you need to try I have a mechanically functioning dp that has the chassis broken in hinges I see that you are from TURIN like me"
                    The registration flag appears to be gravity operated. Either there is a flaw in the plastic molding restricting free movement, or the flag is not adequately counter-weighted. =^..^=
                    • avio2
                      • Jul 2010
                      • 150
                      feel nice, I replicated the error on purpose and given the solution I the manuals I read them all in English while being Italian so see to stop being a bully
                      look my pics
                      I repear the copy from 30 years so you see stop it👍👍👍
                        • 23007
                        I'm not sure where you got the idea, but I wasn't bullying you. And I don't believe that I said anything about your experience. You seem to know your stuff.
                        Your English is certainly better than my Italian.
                        If I am not mistaken, I think I agreed with your conclusions. =^..^=
                        • darry1322
                          • Oct 2010
                          • 817
                          I believe avio2 might have thought your signature file was part of your response.
