6002i dropping developer
  • StratManDan
    • Nov 2018
    • 96
    [Misc] 6002i dropping developer
    Hi everyone!
    I have a Kyocera CS6002i in the field, that is dropping developer into the lower paper trays, below the developer unit. I've checked all the developing bias voltages, and they seem to be in range of service manual specs. I have also taken the developer unit out, and spun it over clean white paper, to see if it's a physical issue with the developer unit itself.
    Has anyone seen this issue, and can give me some points to look at, or a possible resolution?
    Thank you!
  • yakyitz
    • 245
    • tec966
      • Mar 2009
      • 42
      Re: 6002i dropping developer
      Originally posted by StratManDan
      Hi everyone!
      Thank you!
      Change dev unit, this is a know issue, there is a service bulletin about it.
      • StratManDan
        • Nov 2018
        • 96
        Thank you for the info!
          • 23010
          +1
          I had a 3252ci that the only symptom was jamming ... first from tray #1, then from trays #1 & #2. I had noticed a bit of grit in the trays. I cleaned it up and the rollers, and it worked fine for another week. On the third call I accidentally banged the inner cover and 1/4 cup of developer dumped into my newly cleaned tray #1.
          There was no image quality issue to speak of, just jamming. And there isn't an easy way to clean out that front cover without removing it. New developing unit + thorough cleaning solved my issue.
          • StratManDan
            • Nov 2018
            • 96
            Thank you!
