4012i duplex only jamming J4211, J421x
  • toddanderson
    • Dec 2005
    • 233
    I have a 4012i that is duplex only jamming J4211, J421x single sided works fine
    It will duplex jam out of every cassette and bypass
    I did find a QA bulletin 2V6-0014 (J101) on the issue. I installed that and still having the issue. I also replaced the conveying unit, right side door DR6115 drive unit, fuser
    Thanks in advance for the help
  • Santander
    • May 2009
    • 768
    Re: 4012i duplex only jamming J4211, J421x
    I would check out the exit assembly. If the feed rollers have become contaminated or dried out, it could cause enough of a slip in feeding the paper back into the unit on duplex to cause a timing problem where the machine sees the page not exiting within the timing window. The 42xx code indicates the machine is still seeing a page at the exit sensor when the timing window closes. Worth a look.
    • toddanderson
      • Dec 2005
      • 233
      Thanks for your help
      I did replace the exit unit and still have the same issue duplex only jam J4211, j421x
        • 22932
        Not on this model ... but all my references to 4211 jams are associated with the fuser. How new is that fuser? =^..^=
        • JR2ALTA
          • Feb 2010
          • 2028
          If you replaced the fuser, the exit unit, the drive unit, the entire right side door and it's still jamming. I'd start cutting wire ties.
