JAM4311 / JAM 4311 Duplex printing problem
  • bbmworks
    • Jul 2024
    • 2
    [Error Code] JAM4311 / JAM 4311 Duplex printing problem
    Hi everyone. I have a Kyocera M2030DN copier. While direct printing it works normally but in case of double sided printing paper stacks at the rear of the machine. I changed the entire duplex unit and Z44R gear. But I have always the same problem. What shall I do?
  • tmaged
    Owner/Service Manager
    • Oct 2008
    • 1896
    I would guess it's related to the fusing unit. It's usually 4211, but if you're duplexing you may see it as 4311. I would replace the fuser first and see if that resolves it.
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
    • bbmworks
      • Jul 2024
      • 2
      thank you i'll try it
