Kyocera 520i loud noise from toner cartridge
  • copyaction
    • Oct 2007
    • 985
    Old 520i went out to find loud clicking ratchet type noise from the toner cartridge.
    Replaced with another new genuine Kyocera toner in case it was binding. Same noise, then replaced developer unit and drum unit same noise. Spring coupler gear for toner moves freely. I haven’t seen one of these in so long just wondering if I’m missing something obvious?
    • 22973
    This might be your problem right here. I've seen other Falcons break that coupler gear, then it does rotate freely. Or you might have the wrong toner cartridge installed. Falcon I/II used the same cartridge, Falcon III/IV use a different cartridge (TK717/719), FS-9130DN/9530DN use TK-712. Copystar and Kyocera have different toner cartridge drive couplers, I can't speak for the other rebadges. All these toner cartridges look identical but for the drive coupler. =^..^=
    • copyaction
      • Oct 2007
      • 985
      Thanks, I think I have an old one in the shop that I can check the movement on that coupler gear. I meant that the spring loaded part was not binding, like I believe was an issue on some model in the past. The toner they are using in this is correct TK717.
