errrore molto strano
  • manu631
    • Apr 2016
    • 3
    [Error Code] errrore molto strano
    salve, la mia ecosys 6525 visualizza il seguente messaggio: " Controllare la cartuccia toner. Aprire il pannello anteriore della macchina ed estrarre il contenitore toner. Agitare bene il contenotore toner e reinstallarlo."
    sostituiti diverse volte il toner, main board, engine board, toner sensor.
    Aspetto vostri consigliu, grazie
  • Lunatech
    • Oct 2012
    • 208
    La traduzione in inglese;
    very strange error
    hi, my ecosys 6525 displays the following message: "Check the toner cartridge. Open the front panel of the machine and remove the toner container. Shake the toner container well and reinstall it."replaced several times the toner, main board, engine board, toner sensor.
    I'm waiting for your advice, thank you
    • Lunatech
      • Oct 2012
      • 208
      Penso che una nuova unità di sviluppo potrebbe risolvere questo problema.
      I think a new developing unit may fix this.
      con google traduttore
      • Saturn
        • Nov 2023
        • 171
        Please write in English, it is very tedious to translate the conversation every time.
        I don't care about who your father is, as long as I'm fishing here, you won't walk on water.
        • Lunatech
          • Oct 2012
          • 208
          Not all know English and it is often easier to convey a thought in ones native tongue. Besides google translate works well and is not too difficult.
          Nicht alle sprechen Englisch und es ist oft einfacher, einen Gedanken in der Muttersprache zu vermitteln. Außerdem funktioniert Google Translate gut und ist nicht allzu schwierig.
          • Saturn
            • Nov 2023
            • 171
            You're right, if I'm not sure how to describe something exactly, I write it in my native tongue, have it translated using Google Translate or Deepl and then post it in English on the forum.
            I think if everyone does it this way, it makes things easier for everyone.
            • Lunatech
              • Oct 2012
              • 208
              Have you resolved this?
              Also be sure the correct toner is installed. There are other toner cartridges that look the same and are different.
              I hope this helps.
              Hai risolto questo problema?
              Assicurati anche che sia installato il toner corretto. Ci sono altre cartucce toner che sembrano uguali e sono diverse.
              Spero che questo ti aiuti.
