307ci Printing Random characters
  • tsbservice
    Field tech
    • 8013
    #16
    Re: 307ci Printing Random characters
    Originally posted by Samanator
    Yikes! So let me get this straight.
    You installed the Kyocera machine using the same IP address as the old Ricoh machine and then used the Ricoh driver to print to the Kyocera.
    Is that correct or did I misunderstand?
    I think he meant 'correct Kyocera drivers' ...so take a breath 😅
    Anyway back on topic using old printer IP address is not recommended due to many reasons and one of them is exactly this problem.
    • Blizzoo
      • Aug 2013
      • 608
      #17
      Someone or a couple have the wrong driver. Maybe avoid having printer TCP/IP ports duplicates like ex 192.168.0.100_1, _2 etc. Check each PC for driver list in Print Management - delete unwanted and check printer IP ports if duplicate and delete, create new and fresh driver. I would start from here
