307ci Printing Random characters
  • guitar9199
    • Sep 2016
    • 1100
    Morning troops,
    Don't know if this has been asked/answered yet or not, but I have a customer with a 307ci in one of those "Mixed Use" office complexes, that every so often will print out a bunch of pages with the standard "Wingdings" font (Usually seen when someone is using the wrong print drivers). I've enabled User Accounts hoping that would resolve the issue, but short of putting an IP Trap on their network line to find out where those print jobs are coming from, I'm kind of stumped.
    I've already turned off Air Print and Google Cloud Print.. are there any OTHER settings I can use to basically "Lock" the printer from anyone other than those with a valid User ID? I'm fairly new to Kyocera, so I haven't quite figured out all the tips and tricks yet. Any and all suggestions are welcome.
    Thanks in advance!!
  • PrintWhisperer
    • Feb 2018
    • 470
    Re: 307ci Printing Random characters
    Depending on how many clients your are talking about, you can set up the IP filters on the device. You have to enter each IP which will be allowed to access the device. For printing via a server, only that IP should be entered, along with your administration PC, HyPAS app PC's or other authorized hosts.
    If you are doing scan to email I am not sure how this will impact it. I have only made entries to the filter list by IP and not by hostname, I am not sure if it is supported.
    Ensure the device printer settings have the Emulation set to AUTO.
    Disable all other 'printable' ports/protocols like FTP, NetBIOS, POP3, WSD Print, IPP, etc.
    "Being ignorant is not so much a shame, as being unwilling to learn" - Benjamin Franklin
    • darry1322
      • Oct 2010
      • 817
      Originally posted by guitar9199
      Morning troops,
      Thanks in advance!!
      Make sure they haven't setup POP on the machine and it's trying to print incoming email. I've only seen this once. Someone had setup POP3 login info on the machine and it would check email and then empty the paper tray printing garbage.
        • 23006
        Maybe this isn't applicable, but maybe it's NOT a PostScript error (print language mismatch). Occasionally I've seen a poor font substitution cause individual characters to be incorrectly substituted.
        Have you tried changing IP address for the printer? Occasionally I've gotten lucky, and somebody walks up with a laptop, says: " I can't print anymore... ". You look and it's a wrong print driver/wrong emulation.
        Another possibility is the sender is not sending print data at all. Perhaps IT can track packets back to their source with WireShark.
        • copier tech
          • 8142
          Morning troops,
          Thanks in advance!!
          As you say this is usually caused by a user having the wrong driver. It can also be caused with a user is printing via WSD not IP. So I would disable WSD printing to rule this out.
          & as always update the firmware.
          • Santander
            • May 2009
            • 768
            Since you say that you enabled user accounts and still have the problem, did you change the default of permit printing to prohibit under the authorization rules? The default even with user accounts enabled will allow anyone to attempt to print to the unit. Change the setting to prohibit only allows users that can authenticate to print.
            • guitar9199
              • Sep 2016
              • 1100
              Quick update to my dilemma.
              Updated the firmware to newest/latest/greatest with no change. Also disabled all other print protocols, but nothing stopped those jobs. I decided to test a working theory, and pulled the Kyocera to our shop for testing. I left them a Ricoh MP C306 as a loaner to use.
              Wouldn't you know the random print jobs happened on the Ricoh too??
              I'm starting to like the "Different IP Address" suggestion. I'll just need to have the building's IT manager let me know which address is available.
              Will keep everyone posted.
              • Samanator
                • Sep 2017
                • 578
                This only happened to me once but I still check on it when I get prints with wing dings.
                So I get out to this office that we just put in a CS 3550ci. They were complaining about wingdings at the top of the page. Sure enough when I printed anything, there they were. I checked and reinstalled drivers. Wingdings still there. Changed IP address, wingdings still there. I changed the IP address back and was checking on some other thing when the problem just stopped. Don't know what happened it just stopped. I wrote it up and left.
                The next day we got a call and it had started again. Went over to the customer and printed an error log from the machine and the wingdings were on the log. WTF??? Looked in the drawer and the paper in the drawer had wingdings at the top of the page. With the managers help we discovered that the outside sales gal had not had the driver installed on her laptop. She was using the old driver that was pointed to the IP address. Some of the print jobs she sent would make with the wingdings. When that happened, she would turn off the machine, clear the jams, then put the paper with the wingdings back in the paper tray.
                Not that this is your problem but this is why when I get a machine making with the wingdings, I do check the paper drawer. This is also why when replacing a machine of another manufacture or dealer, I try to always change the IP address.
                • copier tech
                  • 8142
                  I would expect this to happen if you installed the Ricoh in place of the Kyocera & used the same IP address.
                  • Blizzoo
                    • Aug 2013
                    • 608
                    On my installs I always ask for new IP address for the new printer and avoid using the old printer IP. Keeps things simple and less problems.
                    • copier tech
                      • 8142
                      I use DHCP to pull the network details then set the IP static.
                      • tmaged
                        Owner/Service Manager
                        • Oct 2008
                        • 1879
                        You really shouldn't do this unless there is a competant network guy onsite to create a reservation. If there was, they would probably give you an address.
                        It should be set outside the DHCP scope so no other device could possibly get this address assigned.
                        Hope that helps !
                        -Tony
                        www.dtios.com
                        Become a fan on Facebook
                        • copier tech
                          • 8142
                          • guitar9199
                            • Sep 2016
                            • 1100
                            The Ricoh was using the same IP address, but I installed the correct Ricoh drivers.
                            • Samanator
                              • Sep 2017
                              • 578
                              Yikes! So let me get this straight.
                              You installed the Kyocera machine using the same IP address as the old Ricoh machine and then used the Ricoh driver to print to the Kyocera.
                              Is that correct or did I misunderstand?
