White and black lines Kyocera M3550idn
  • wolfcub
    • Sep 2024
    • 4
    Hello,
    I have replaced the entire MK-3130 kit on my Kyocera M3550idn:
    • Black Drum Unit [302LV93062]
    • Black Developer Unit [302LV93080]
    • Fuser Assembly [302LV93132]
    • Separation Roller [302F909171]
    • Feed Roller Assembly [302LV94270]
    • Transfer Roller Assembly [302LV94130]
    Unfortunately, even after replacing all the parts, the print still comes out with white and black lines as shown in the picture. What could be the cause?
    Thank you.
    This gallery has 1 photos.
  • Ropariva
    • 676
    Did you put it in “Developer” mode through Adjustment/Maintenance?
    • wolfcub
      • Sep 2024
      • 4
      Yes, already done! Nothing works!😥 It was printing almost the same with the old kit that I removed.
      • KdvA
        Engineer
        • Aug 2008
        • 10
        It is worth replacing the HVU / Engine PWB. This is located from the bottom behind the Duplex Section. This PWB has a lot of contacts that can cause problems. This PWB may be defective
        • wolfcub
          • Sep 2024
          • 4
          Thanks for the advice, I tried reinstalling the old kit and the streaks are practically the same.
