main board Ta 3510i
  • happicopy
    • 51
    main board Ta 3510i
    I've ordered main board for TA 3510i from my supplier.
    He said that it cannot be shipped because of the battery
    .He ask me if he can remove it . I said yes and i will just replace it once i received the main board.
    My question is what problem i will encouter after replacing the battery?
    Do i need to do anything before i replace the battery?
    TIA
    • 23010
    Re: main board Ta 3510i
    You'll probably have a C-0840 greet you at bootup, and/or "Time for Maintenance T".
    Observe the qualifications about replacing the main PWB:
    swap the original EEPROM onto the new PWB at YC14
    swap any memory DIMMS onto the new PWB at YS1 & YS3 (SAME POSITIONS PLEASE)
    install the new battery
    load firmware immediately before proceeding further
    Run U026 restore backed-up data
    Run U278 delivery date
    Run U402 margins
    Run U952 to register settings
    You may need to run U906 to clear the C0840 error or to clear the time for maintenance message.
    Set date/time
    Set timer settings (if any)
    Re-enter addressbook & job accounting data or restore with U917
    Re-enter printers IP address.
    It's all on page 426 of your service manual. =^..^=
