I have 6052ci with C7903
  • toddanderson
    • Dec 2005
    • 238
    I have replaced drum units, image feed pwb, drum developer relay pwb, engine pwb
    I also notices that the serial numbers are missing from all the units drum
    DV, transfer belt and fuser looking at the serial number modes
    U117,u984,u122,u165
  • kuby
    • Oct 2007
    • 1411
    Re: I have 6052ci with C7903
    Is the firmware up to date? v.4.10
    • toddanderson
      • Dec 2005
      • 238
      yes updated firmware multiple times
      • kuby
        • Oct 2007
        • 1411
        Did you run the Turbo or the Full? Kyocera says if you are having issues to run the Full version instead of the Turbo.
        Did you contact support and see what they day?
        • JR2ALTA
          • Feb 2010
          • 2033
          Our similar issue our rep came out and installed a brand new PM kit fixed it. Always unplug machine on these too, for proper serial number resets.
          I know it sounds unbelievable but I think the idea is a corrupt consumable and just shotgun it.
          • KYO_OEM
            • Aug 2011
            • 725
            It also can be a broken DV unit....
            I would disassemble all 4 DKs and DVs and reassembling only step by step
            Start with BK DK---BK DV----MG DK---MG DV----until you reach yellow units
            After each step i would check SNs by U117 + U984 until i found the broken one.
            By the way:
            You can be happy that it happens on xx53ci instead of xx54ci.
            If C7903 or any other print unit related C-Call will appear on new series, no way to enter LLU related service points.
            NO U110, U117, U127, U158, and so on.....
            I checked the new Partial Operation Function for training and found that the
            "Partial Operation Function" will prohibit the entrance to these important service points.
            At the moment i am fighting against KDC because of this behavior.
            They won`t accept to activate these SPs again...
            They wrote that these SPs are still available, but they forgot that we must use 1087 1087 instead of the factory code (xxxx****)
            My 1. training course will start next week and i has to tell the guys that its still under investigation because it won`t work as descriped....
            • rjohnson843
              • 7
              Hi did you ever find a solution to this i have one giving me codes c7901-c7904
              • KYO_OEM
                • Aug 2011
                • 725
                sometimes no serial numbers available.
                No DV, no dk
                both components are connected to drum developer relay pwb
                If we do not get power supply from feed image pwb, feed image pwb maybe broken
                additional check from fk and belt serialnumbers
                also no number, feed image pwb
                we have had 1 broken unit which breaks the serial communication
                In this case to has to disassemble each LLU part and assemble again back to back.
                Each time you has to check if the number would shown by the service point.
                e.g. have had broken dv unit yellow, but system showed C7902 /cyan drum missing instead of C7914
                mostly no serial number visible because of broken drum developer realy pwb or feed image pwb.
