kyocera 3051 c2810
  • adel_nathan
    • Jul 2011
    • 103
    [Error Code] kyocera 3051 c2810
    hi ,
    First sorry about my English it's bad but i will try to explain the problem. I have Kyocera 3051ci with c2810, i found the waste toner motor didn't rotate and i found out that the waste toner is become like stony > then i changed the waste toner motor unit with another and check the waste toner path from hopper to waste toner box , it was clean and appears good> but after 3 days i have another call from same machine about same error code 2810 > go and the situation was same waste toner is stony and motor didn't rotate , i did like the past time and the machine work for another 3 or 4 days and repeated again. via this story i change the following ( waste toner motor - transfer belt - hopper unit ) and all the parts that change when install in another machine it works good....... please i need help
  • dalewb74
    • Feb 2018
    • 1167
    is it kyocera toner? what is the environment like?
