Kyocera FS-3920DN Optional Network Card Setup
  • stern.detmold.32756
    • Feb 2018
    • 25
    We have a Kyocera FS3920DN with a broken LAN-port (It works but it doesnt grip the cable anymore).
    We also have several Kyocera MDK332V-0 network cards. They fit and blink when installed, but I can't get them to work.
    I set the printer up the way it usually works (with the integrated network), static IP, Subnet Mask, Default Gateway.
    When connected to the MDK332V-0, the printer does not seem to have a connection.
    The Network Status Page also states the internal MAC Address and IP Adress, Subnet Mask, Default Gateway are "Not Defined". Optional cards are not blocked via the security menu.
    Does the FS3920DN not support the MDK332V-0 or do I have to set it up differently?
    Thanks in advance
  • PrintWhisperer
    • Feb 2018
    • 472
    Re: Kyocera FS-3920DN Optional Network Card Setup
    Not supported, IB-21E is for FS-3800.
    No supported card for your device, FS-2020D only device in series to support OPT network card IB-31.
    You have a parallel port so hook it like it's 1999.....parallel print server (i.e. Jet Direct box)
    "Being ignorant is not so much a shame, as being unwilling to learn" - Benjamin Franklin
