Kyocera 3553ci LSU Cleaning Motor (c4600 error)
  • chemicalx50
    • Apr 2014
    • 39
    [Error Code] Kyocera 3553ci LSU Cleaning Motor (c4600 error)
    Hello everyone,
    I'm currently experiencing an issue with a Kyocera 3553ci that keeps showing a C4600 error. It also makes a loud clicking noise, so it seems like the motor is basically locked up. I looked up the error code, which points to a problem with the LSU Cleaning Motor.
    I've removed the LSU, and all the gears seem okay. The cleaners slide perfectly by hand without issues, but I can’t understand why the gears won’t turn when I try. I also removed the gears from the motor, and the motor spins freely by hand. I'm considering disconnecting the motor altogether, but I wanted to check here first for any advice or suggestions.
    Thanks in advance for any help!
  • KYO_OEM
    • Aug 2011
    • 725
    take care for waste toner drive motor!
    Both. LSU cleaning motor and waste toner drive motor get 24V by YC27/ pin7, 8 from engine pwb.
    Have had several cases with C4600 because of broken WTB motor.
    The WTB motor breaks down the 24V circuit....
    • chemicalx50
      • Apr 2014
      • 39
      I found a temporary fix. For some reason, the LSU motor still works but makes a lot of noise, so I swapped it with the waste toner motor. I can see it’s working but still making noise, so I ordered a new motor. Thanks again, guys!
