FS_C5030N with Error code 953
  • Jimbo1
    • Mar 2008
    • 845
    We have replaced the LED array with a known working one, replaced the drum and deve units, the main and engine board and also the eeprom. It still comes up with the same code. Anyone have a ideas please let me know.
    "Some days you get the bear, some days the bear gets you."
    Cdr. William Riker
    • 22999
    From what I've read, the most likely candidates are:
    1) the LED head on the magenta drum unit,
    2) the Print Heads Relay PCB,
    3) the Engine Controller
    4) the mating connector & harnass.
    It looks like you got 1 & 3. That leaves 2 & 4. =^..^=
    • Jimbo1
      • Mar 2008
      • 845
      K, so we did 2 and 4 and we still have the problem.
      Mucho gusto O great BlackCat. Any other idears?
      Cdr. William Riker
        • 22999
        That's all I got. When I run out of ideas I start rechecking the old ones.
        Since the LED head remains the most likely, I would try switching the magenta LED head with one of the other ones, to see if I can get the problem to move. If it doesn't move you've completely ruled out the LED head as the source of the problem.
        Have you tried flashing the machine? I know that sounds desperate (the kind of advice that you'd get from the hotline).
        When do you get the code? Does it complete initialization? If no, how long? =^..^=
        • Jimbo1
          • Mar 2008
          • 845
          Well everything on the list has been replaced and yes we flashed the machine.
          I'm not actually the person with the hands on but I think it gets through initialization.
          This all came about from a tech searching for a sqeuak. He is very experienced with these. He went working in the right hand side of the machine and it started coming up with this code and it won't quit.
          I think the power supply is the only thing left. Even changed the main board.
          Just got verification it gets through initialization.
          Cdr. William Riker
          • Jimbo1
            • Mar 2008
            • 845
            Resolution
            They found a bad ribbon cable on a drum unit other than the magenta.
            Imagine that!
            Thanks for all the help!!
            Cdr. William Riker
              • 22999
              I've followed up on a few problems like that. One was a Sharp AR-507 that was giving motor driver codes. On the ribbon cable only one of the foil contact points had peeled back. Good catch. =^..^=
