Ghosting when doing multiple copies
  • MAW
    • Mar 2019
    • 12
    Good morning
    I'm having a issue a Kyocera TASKalfa 3552ci the customer getting a ghost image on there copies making 10 or more copies anything least the copies are fine. I have upgraded the firmware check clean all contacts on drum unit and transfer unit the copier works fine for a couple of and the problem returns I have also replace the primary transfer unit any ideals what happens with the copier
    thank you
  • dave w
    • Jun 2015
    • 230
    Re: Ghosting when doing multiple copies
    Sounds like a fusing unit issue.
    • Tonerkiller
      • Oct 2012
      • 669
      The paper weight settings may be wrong.
      • Scott
        • 198
        Also check drum, is it just one color ghosting?
        • PrintWhisperer
          • Feb 2018
          • 474
          This is a symptom which was observed on early model transfer belts before the material was changed. When outputting the same image over and over there would be ghosting of actual image without background due to poor transfer belt cleaning.
          OEM Toner and Belt?
          I like the idea of changing the media type settings to heavier stock and you might try turning on MM335 and bump the page interval up a couple steps to see if that reduces the load on the belt.
          "Being ignorant is not so much a shame, as being unwilling to learn" - Benjamin Franklin
          • avio2
            • Jul 2010
            • 150
            • MAW
              • Mar 2019
              • 12
              Good morning,
              the fuser unit is good and I replace the transfer unit I'm going to replace the drum unit seeing they have had the copier three years but only a 178000 copies on it I also try the U161 fuser adjustment. thank you for all your suggestion I will take them into consideration and post my results
              • kjg
                • Mar 2009
                • 112
                I find that series to be very picky to power. If you cannot find a resolution, try moving to another outlet. Be sure it is a clean outlet. Try it there and see if it clears up. Hope that helps.
                • ntbann
                  • Jan 2012
                  • 632
                  We have solved this by putting the paper trays to 24lb.
                  • MAW
                    • Mar 2019
                    • 12
                    The problem solve there three media types setting that you can change that make for the type of paper that be used in the copier type 1 is the default setting also the problem can be the fuser unit
                    • craigster
                      • Apr 2016
                      • 201
                      I would be checking fuser and media settings for the paper or possibly drum. Does it do it on all colors?
