Kyocera/Copystar 6525 DP 470 cover latch hooks
  • Woody214
    • Oct 2015
    • 29
    [Misc] Kyocera/Copystar 6525 DP 470 cover latch hooks
    Anyone had to replace the rear or front white latch hooks which keep the DP top cover closed/latched? Can not find them in the parts manual.
  • craigster
    • Apr 2016
    • 201
    Re: Kyocera/Copystar 6525 DP 470 cover latch hooks
    looking at parts manual pretty sure you need to replace the the part cover feed assy 303M894052.
    • Woody214
      • Oct 2015
      • 29
      The latches are connected to front and rear lower frames and then cover engages once closed. Not part of the cover.
        • 22999
        Is this the feature that you're looking for? If yes, you'll have to call the hotline to start a part number inquiry. It's not labelled separately (the front frame doesn't seem to have a part number either). =^..^=
        • Woody214
          • Oct 2015
          • 29
          • Santander
            • May 2009
            • 768
            We have only had to replace the hook on the backside of the DF and the PN is 3HL07170. It does not appear in the parts list, we got this number from Dallas a couple of years ago, i would have thought that the parts list would have been updated by now. If memory serves me correctly the latch can be used on either side. Hope this helps.
            • avio2
              • Jul 2010
              • 150
              yes hook is this :
              parts manual DP480
              L07170 3HL07170 REAR HOOK PF COVER 1 1 1
              303HL07161 3HL07161 FRONT HOOK PF COVER
              • Woody214
                • Oct 2015
                • 29
