kyocera fs 1118 please wait problem
  • fatthyzz
    • Feb 2010
    • 10
    Hi
    After dismantling the main board to treat the registration clutch, and after installation, it appeared(please wait)
  • JR2ALTA
    • Feb 2010
    • 2033
    Re: kyocera fs 1118 please wait problem
    Do the optics bump? Does the fuser get hot? Have you reseated everything?
    • Ropariva
      • 695
      Are we talking about a 13 year old machine?
      Time to retire it I think
        • 30476
        Reseat all the connections
          +1
          • copykat93
            • Oct 2021
            • 281
            I'm sure if you re-trace your steps, just act like you're doing the same service all over again, you will find a connector not pushed in all the way or maybe in the wrong spot. If you had a reg issue and no other problems, then it is in the reinstall of all your steps.. just do the job over again from the beginning & you will probably have a better outcome. Good luck & keep us posted how it goes.. It is an old machine, but if the issue wasn't there before you tore it apart, then just redo it & you'll be fine. After that, if it doesn't work, take it out back & smash it with a sledge hammer, it always makes me feel better....LOL
