KM-6030 Dead Document feeder
  • Vorky
    Hi
    I got a KM-6030 where the document feeder seems totally dead. Ive checked all wires wich seemed ok.
    Anyone whos had the same problem? Any suggestions would be nice
    Thanks in advance
  • kyoceradude
    The Great Gazoo
    • Aug 2006
    • 442
    Have you performed a reset-disable? Sim 906?
    My mission here on Earth is to help all you Dum-Dums!
      • 22999
      Once you've done the 906 reset, get out your VOM and check for the standard voltages to the DP controller, typically +5vdc, & +24vdc (check your schematic for test points and voltages).
      • Vorky
        Im quite new to this so no I havnt performed a reset-disable
        Gonna try this out
        Thanks for the help kyoceradude and blackcat
        • vikingmita
          • Nov 2008
          • 163
          over til norge: hvor jobber du?
          • jasonofx
            Service Tech
            • Nov 2006
            • 64
            I had to replace the doc feeder cable on one of these before. I can't remember how expensive it was, but it might be a cheaper way to diagnose as opposed to a board.
