Kyocera M3540idn Power Supply
  • DougMoney
    • Feb 2017
    • 70
    I am working on a Kyocera M3540idn that needs a 120V power supply. The one I pulled from the machine is 302KV45020 but the manual shows I need a 302NX94050. Have any of you gone through this? Thanks for your help.
    • 23008
    Re: Kyocera M3540idn Power Supply
    You need to look at the "Notes" column. The ECOSYS M3540idn is the 42ppm 4-in-1
    You can confirm this in the release Bulletin:
    ECOSYS M3040idn/M3540idn: 302NX94050
    ECOSYS M3550idn/M3560idn: 302LV94080
    I know, it's confusing. Why couldn't they have just listed the appropriate model numbers? =^..^=
    • DougMoney
      • Feb 2017
      • 70
      Black Cat, I understand the numbers in the manual. What I am asking is the board I pulled from the machine does not match that number. The number on the board I removed is 302KV45020. It is printed right on the board. Is this number just the blank PCB? I am trying to find why the number on the board is different from the manual. Thanks.
        • 23008
        The numbers printed on the board are just the naked PCB without components, and can be built in different ways. Those part numbers never match the numbers in the parts manual. =^..^=
        • DougMoney
          • Feb 2017
          • 70
          That's what I thought. Thank You.
