I went to look at a 5054 for a scan to email issue. Ran the test from the command center and got a 3201 error code. Typed the smtp account password in manually and tested and it worked again. Cool. Went to hit the submit button and then I get a pop up box that says
*IP Address* Says Select the Item
With an OK button.
No Idea what to do with that. I tried another machine at the same location and had no issue hitting submit. Anybody run into this box before?
With an OK button.
