This TASKalfa CS-250ci ran fine for the first three weeks, until I installed the 1000 sheet finisher.
About once a week I get a call for "Finisher out if order". This last visit I pulled off the covers & tried to get it to pull the code. The motor that lifts the upper eject rollers is unstoppable, and my fingertips are raw from failing to stop the drive. The roller sensor changes state when it should.
The firmware is at version 3.04 combined/1.02 options. My only recourse right now is to move all the outputs away from the finisher tray.
Has anyone had the C8350 codes? And what did you find? =^..^=
