M3540D makes noise in sleep mode.
  • yoni725
    • Nov 2021
    • 5
    The printer constantly checks the connection to the computer. About every 2 minute green bulb signal. If I hang out the printer from the computer, the bulb is on, fixed on sleep mode.
  • yoni725
    • Nov 2021
    • 5
    Re: M3540D makes noise in sleep mode.
    Can a factory reset fix the problem?
    If so, how do I do it?
    The exact model M3540DN
      • 22999
      Not that it's a huge crisis that a fan still runs ... but you can set the sleep mode to a certain value ... say 5 minutes, then low power mode to 6 minutes. See page 8-38 of your operators manual ... or get it here:
      Product Support & Downloads | Kyocera Document Solutions America
      Explain to me how the normal functioning of cooling fans is a crisis. =^..^=
      • yoni725
        • Nov 2021
        • 5
        I probably did not explain the problem properly
        The noise is not from the fan
        When the printer is in sleep mode, the green light is on all the time "Energy Saver"
        But when the printer is connected to a USB or LAN computer
        The light bulb is blinking. Then it turns on continuously, and flashes again, and any transition between flashing and continuous on, makes a sound from the printer
        • diedux
          • Jan 2017
          • 124
          If you mean relay clicking sound it's completely normal. So easy fix - ignore it.
          • yoni725
            • Nov 2021
            • 5
            Yes it is the noise
            I have 4 printers in my office.
            Any printer that passes into a quiet state makes such a sound. And that's okay.
            But this printer makes the noise every 16 seconds (I checked now)
            • diedux
              • Jan 2017
              • 124
              You can try to disconnect the USB and network cable. This ensures that no outside "source" is trying to connect to the device. If this doesn't help, try to reset the device to factory defaults. In CCRX go to Management serttings>Reset>Reset device to factory dafaults>Initialize. Check if reset had helped before reapplying any configuration.
              • yoni725
                • Nov 2021
                • 5
                If I disconnect the USB and LAN
                The printer enters sleep mode. A green light is on all the time.
                And makes no noise
