taskalfa 3500i
  • Gab
    • Aug 2015
    • 676
    taskalfa 3500i
    Occasionally dark lines ,like those in the attached file, appear at the copy. Especially in the morning
    i cleaned machine and replaced charge roller with no result.
    Toner is katun but never had that problem in other machines.
    Any idea?
  • rapo_tech
    • Feb 2019
    • 114
    Re: taskalfa 3500i
    This is caused most certainly by charge roller.
    Did you replace with new charge roller?
    Did you run U930 after replacement?
    -e- it might be faulty developer also...
    • Ropariva
      • 697
      Re: taskalfa 3500i
      Any idea?
