Kyocera TASKalfa 3252ci
  • Kriess
    • Feb 2025
    • 8
    Hello!
    There is a problem with the transfer belt unit.
    I attached a photo.​
    What I did:​
    -I cleaned all charging rollers.
    -I cleaned and vacuumed the transfer belt blade and under the transfer belt blade.
    It was still bad​.
    The drums is not worn out​.
    I would like to ask for help.
    This gallery has 1 photos.
  • KYO_OEM
    • Aug 2011
    • 725
    Before exchange from parts check U465/ stress value. Both must be >90, if values closed to 90, surface from belt damaged and new belt needed.
    • kuby
      • Oct 2007
      • 1410
      How many copies on machine. OEM toner or Generic, How many copies on the transfer belt?
