4054ci solid cyan image
  • toddanderson
    • Dec 2005
    • 238
    I am working on a 4054ci with a solid cyan copy edge to edge,
    I already replaced the Main HV, engine and image pwb
    Has anyone ever check the high voltage output for the charge rollers ?
    At the board and what the reading should be, I think it would be different
    If it was a 2554ci because the drums are different OPC vs ceramic
  • Larhal
    • 609
    Usually the full page coverage is due to the Drum Ground or lack there of. Swap drum units with another one to see if it happens the same. If the Cyan drum unit exhibits the same problem when run in another colour then the drum unit is bad.
    Larhal
    If all else fails read the Service Manual!
    If that fails, meet me at the pub and we will discuss it.
