Kyocera ECOSYS P7035cdn Command Center Password
  • markus
    • Dec 2021
    • 12
    Hello
    I bought a used printer. The problem is I can not get into the webinterface. I do not know the password. The default password does not work.
    How to reset the password ?
    I have the password for the printer itself which is needed on the display.
  • JR2ALTA
    • Feb 2010
    • 2033
    Re: Kyocera ECOSYS P7035cdn Command Center Password
    What are you trying?
    • markus
      • Dec 2021
      • 12
      I want to log in at the webinterface.
      I test Admin Admin
      Admin admin00
      • Ropariva
        • 693
        Also try 3500/3500.
        • markus
          • Dec 2021
          • 12
          Unfortunately it doesn't work either.
          • JR2ALTA
            • Feb 2010
            • 2033
            Read thoroughly
            Kyocera FS1135 rest Command Center password
            • markus
              • Dec 2021
              • 12
              Unfortunately I have already tried everything with my P7035cdn does not work.
              I can send commands to the printer. The commands for test pages work. But it does not respond to password reset commands.
                • 30441
                call 1 800 get Mita
                they should provide the reset prescribe comand
                if you not a dealer use the customer option
                • markus
                  • Dec 2021
                  • 12
                  It's not that simple in Germany. Here one would like to have 0.99 euros per minute for end customer service. But I will probably have no other option.
                  And you can only call in the week until 6 p.m.
                    • 30441
                    They must have a hotline in your Germany visit the web page for support and call that number.
                    good luck
                    • markus
                      • Dec 2021
                      • 12
                      I called.
                      Only a local technician can fix it.
                      They don't want to help me on the phone.
                      The printer is strongly encrypted.
                      The firmware must be reflashed.
                      The service company would first have to contact Japan for the firmware.
                      • sparkycivic
                        • Apr 2017
                        • 348
                        Are you able to login to the operation panel locally? 3500/3500 should work from there. You'll be able to perform any pertinent configuration from that interface.
                        • justanotherhack
                          • Apr 2015
                          • 74
                          I think the password can be reset through the control panel: <menu><user login/job account><user login> If prompted for a password, use 3500, 3500
                          • markus
                            • Dec 2021
                            • 12
                            All Ok
                            The Service reset the Password by flash the firmware.
                            But it costs 97 euro.
