kyocera fs6530 scanning to email
  • mohammad42
    • Jan 2022
    • 10
    hello guys
    ı have a customer with kyocera fs 6530 i have problem to scannig email pdf format to outlook
    the customer has an internal exchang server evreything is ok ther is no connection error and kyocera says complet and ok in stause section
    and i scanning jepg evrything is ok email is receved its just pdf problem
    thanks for helping good days
    • 30444
    Re: kyocera fs6530 scanning to email
    Check the mail server it must be filtering the attachment
    • copier tech
      • 8196
      Originally posted by mohammad42
      hello guys
      Try updating the firmware.
      • mohammad42
        • Jan 2022
        • 10
        thanks for replaying guyes the firmware is latest 2017
        if mail server filtering problem there is kyocera fs 1130 pdf mail is working fine without problems
        is there any idea?
        thanks alot.
          • 30444
          is there any idea?
          thanks alot.
          Is it using the same sender and subject line?
          Email filters work on both to detect spam email
          If it's leaving the machine the problem is on their end
          • mohammad42
            • Jan 2022
            • 10
            thanks for replaing bsm2
            exactly its using the same sender and subject line
            there is nothing in spam email
            in kyocera status section its says completed and ok its meaning job leaving the machine
            i tried another user pc one time email arrived pdf format and then same problem just on time
            there is an anoying IT man he said why fs 1130 is working fine but fs6530 not working tow machine same internal exchang server .
            why jpeg is working fine .
            its werd .
